U-Joint GMB-210-1200
Weasel
Post by Weasel » Sat 11 Apr 2015, 19:56
Driveshaft decided to fall out today, the U-Joint is pretty worn. looked up and found the part im looking for is GMB-210-1200 and it doesn't seem to be available here. my guess is its imperial sizing?, so my dumb question is; is there some universal universal joint sizing whatnot that im not aware of, or is there supplier that will have this.
Re: U-Joint GMB-210-1200
Post by IndianaJones » Sun 12 Apr 2015, 14:38
There is a supplier that will have this.
GMB is only one manufacturer of universal joints, other manufacturers might use a different part number.
For what vehicle is it, and does it have it's standard driveline?
Weasel
Post by Weasel » Sun 12 Apr 2015, 16:23
Ok thanks, didnt know gmb was manufacturer, i thought it was part of the part no. Its for a d100 dodge 1959 and it is the srandard driveline.
Post by ters » Sun 12 Apr 2015, 18:28
Have you joined the Mopar owners group yet? ;) On Facebook: https://www.facebook.com/groups/moparownerssa/
Post by IndianaJones » Tue 14 Apr 2015, 11:43
Have you found GMB part nr 2101200?
If Autozone/Midas, etc doesn't have stock, even BMG/Bearing Man should be able to supply.
Weasel
Post by Weasel » Sun 03 May 2015, 19:26
haven't found one yet but i haven't been looking :( been rather busy and it doesn't look like it will be a quick swap, it will have to be welded in somehow. Bakkie did however get a new carb and master cylinders :D
Doug Hirkham
Post by Doug Hirkham » Wed 06 May 2015, 10:18
[quote=it doesn't look like it will be a quick swap, it will have to be welded in somehow. [/quote]
Better post some pics - sounds like you are barking up a very wrong tree.
Weasel
Post by Weasel » Wed 06 May 2015, 15:24
Lol ok, here's what i mean, the front segment on the drive shaft is welded and i don't see how the joint will come loose without some cutting.
Hubcap
Post by Hubcap » Wed 06 May 2015, 15:39
Front segment is pressed fit. Probably internal clip.
Johann72
Post by Johann72 » Wed 06 May 2015, 16:09
Pardon my ignorance!! Is that not a prop shaft! 8O 8O
Used to be known as Johann65.
1965 Chev Malibu Sold
1966 Volkswagen Sold
1954 Hillman Californian Sold
1954 Triumph TR2 Sold
