1965/66 Opel Rekord L Rally GMSA
Johann66
Re: 1965/66 Opel Rekord L Rally GMSA
Post by Johann66 » Wed 27 Sep 2017, 19:39
barrydorr wrote:
Thu 14 Sep 2017, 17:48
Always good to have spare, specially in die Vaal with all the potholes...
Vereeniging is unbelievable! You can break an Axle!
Johann66
Post by Johann66 » Wed 27 Sep 2017, 19:47
Working on the Opel does not stop! It will always be a project! Here are the readings at 500 Rpm (Cold) and later at 1400Rpm (Warm)
Cold 500 Rpm
Cold
Cold
Warm 1400 Rpm
Warm
Warm
Mechanical
Johann66
Post by Johann66 » Wed 27 Sep 2017, 20:13
My next issue is the brakes of the Opel! Calipers are working well but the hydraulics are terrible! I suspect that some of the pipes are blocked as I cannot get the fluid to flow through! Can I put pressure on the pipes after disconnecting them from the cylinders?
bmwmaniac
Post by bmwmaniac » Wed 27 Sep 2017, 21:01
if you are referring to the rubber hoses, rather have new hoses made up.
"If you park your car, walk away and don't look back, you're driving the wrong car"
Johann66
Post by Johann66 » Thu 28 Sep 2017, 13:37
Sorry, these are the steel brake pipes from the Master Cylinder. The rubber hoses are OK, replaced one! Nearly misunderstood! No leaks.
Bleeding
Johann66
Post by Johann66 » Thu 28 Sep 2017, 13:53
Driving Lights.
My preference
With Mbar.JPG (136.24 KiB) Viewed 70513 times
Lights too close
Without Mbar.JPG (160.49 KiB) Viewed 70513 times
Johann66
Post by Johann66 » Thu 28 Sep 2017, 21:25
I have been recommended to a brake specialist by the Rimtek who fixed one of the Opel's rims. He will come to my house tomorrow! Fortunately he is very close and it is his trade!! Hope all comes right! I am dying to go driving!
Johann66
Post by Johann66 » Thu 28 Sep 2017, 21:29
In the mean time I am covering the steering with vinyl to get that leather feel!
Nearly complete! vinyl taking to the shape!!
If you notice the Original Speedo, Got a working unit from Chevyworld and rebuilt the original and repaired the speedo cable. Dying to test it against the GPS!
First V8
Post by First V8 » Fri 29 Sep 2017, 08:18
:D Looking good Johann . You realy are paying a lot attention to fine detail to get the Opel looking like original .
2010 Chev Lumina SS
1968 Chevy Impala (SOLD)
1968 Vw Beetle ( SOLD)
1963 Mini Pick Up ( Exported to UK )
Johann66
Post by Johann66 » Sun 01 Oct 2017, 18:16
I've got to keep me occupied! So called brake specialist never pitched up!! It appears that the right rear caliper needs to be adjusted! Looks like that I will be doing it self! Save me some bucks!!
Users browsing this forum: No registered users and 10 guests
