XR8
- alvin chetty
Re: XR8
on the drivers side chassis leg there is a serial number stamped. under the drivers side headlamp will be a body tag saying its a xr8. some of the speedo cluster got v8 printed in red on the top corner. the distributor is in front of the engine and not at the back
Google wont keep you out of Jail
- alvin chetty
Re: XR8
they are numbered RY 001 to about RY 250 (not sure of the exact number made)
Re: XR8
Important this because so many cars have had the bumpers sprayed black (I actually prefer them black)HIGHBOY wrote:bumpers and door trims blue not black
- colin davids
Re: XR8
Hey VishVish wrote:Where on the car will I find this number. Also will this number correspond with the engine number like the Perana's do?
The series number Alvin is referring to is in fact on the back of the block behind the intake. The sierra xr8 does not have a corresponding number on the body.Apart from the points already mentioned it also has a rectangular pressed steel panel running across the front of the radiator with attaching points for the grille.Interior trim is xr8-specific as is the steering wheel,A.P. racing brakes,completely different rear subframe with granada type differential and heavy duty axles.Dipstick tube should come out of the block and not the timing cover as on more common 302 engines.
Of course if you find the distributor issue that Alvin referred to there is no need to continue.
Hope this helps
Colin
FORD CAPRI PERANA NO. 66
FORD CAPRI V8 DRAG CAR
FORD SIERRA XR8
FORD CORTINA 3.0 S W/CHEVY V8
BMW E30 W/ FORD 347 STROKER
1970 MUSTANG MACH 1 MANUAL W/4V CLEVELAND
SUZUKI GSXR 1000
FORD SAPPHIRE 2 LITRE 16 VALVE TURBO
FORD SIERRA XR8
SUZUKI GSXR 1000
Users browsing this forum: No registered users and 35 guests
