V8 ford capri project
IbanezRG
Re: V8 ford capri project
Post by IbanezRG » Thu 04 Oct 2018, 14:56
Hi All,
So I did manage to find a Holley carb and intake manifold.
I have decided to use my stock cast iron exhaust manifolds for now.
I need to have a look at my diff to see if I can figure out what diff it actually is.
in regards with the engine mountings, i have one of the below, the second one is broken in half. My question is, are these the correct mountings to use on my Capri ? I would have to build some kind of an adapter to make it fit onto the crossmember. can you guys help me out with some pictures and measurements of what I need to build?
IbanezRG
Post by IbanezRG » Sun 07 Oct 2018, 12:06
So I had a look at my Capri's diff as well as the other one I've got. They both don't have identification tags and I cannot figure out what diffs I actually have. Maybe you guys can help me out here.
So this is my Capri's diff, all I could find on it is the letters MC and .92
and this is the other one I've got, all I could find on this one was Borg Warner (its got lots of gunk on it, will clean it next time I'm there to see if it has any markings):
IbanezRG
Post by IbanezRG » Wed 10 Oct 2018, 09:38
its sad to see how quiet this forum has gotten over the years... I used to get lots of advise here
Punch
Post by Punch » Wed 10 Oct 2018, 12:16
If you are trying to find out the diff ratios you are lucky because you have removable back plates on both diffs. Remove the back plates, count the teeth on the crown wheel and on the pinion, divide the number of teeth on the crown wheel by the number of teeth on the pinion. this will give you the ratio. eg : - 65/22 = 2.95 :1
Use a spot of tippex to mark the first tooth you start counting from.
IbanezRG
Post by IbanezRG » Wed 10 Oct 2018, 15:27
Awesome, thank you so much for the info
marnus
Post by marnus » Wed 10 Oct 2018, 16:39
the one in the capri seems to be M68
The other one however looks like it may be a M75/M78 BW
Johann66
Post by Johann66 » Sat 13 Oct 2018, 10:55
Getting Old?
IbanezRG
Post by IbanezRG » Thu 18 Oct 2018, 07:42
Getting Old?
:lol: yeah I'm definitely getting old, Its crazy to think I started this thread in 2011, I was 23 at the time..
IbanezRG
Post by IbanezRG » Thu 18 Oct 2018, 07:43
Hi All,
Can anyone comment on the engine mountings and maybe help me out with a photo or two ?
marnus
Post by marnus » Thu 18 Oct 2018, 09:27
Hi All,
For starters, what does your current cross member look like?
Is it the standard v6/2l cross member?
