V8 ford capri project
- paulusvrotius1
Re: V8 ford capri project
Hi, your grille is an early '69/'70's one and should have an alloy dummy grille attached at the rear of the bulge. They are quite rare.
I can't seem to upload pics at the moment but will do so as soon as I can.
- paulusvrotius1
Sorry, above should read bonnet not grille.
You can see the extra piece on the bonnet of my car.
You should try to repair your bonnet if possible.
- PR (04).JPG (140.04 KiB) Viewed 3137 times
- paulusvrotius1
Here's the other type of bulge, courtasy of Chris' A2 replica.
I'll get some close-ups of my bonnet for you tomorrow.
- Capri bulge.jpg (61.13 KiB) Viewed 3119 times
- zahistorics
I agree with Paul. that bonnet is far too good to cut up or throw away.paulusvrotius wrote:...You should try to repair your bonnet if possible....
unfortunately its not possible to repair the bonnet. its just bent very badly and the supports bent. i've tried to strip the supports from the bonnet skin, hoping to get them strait but with no luck, just to much damage.zahistorics wrote:I agree with Paul. that bonnet is far too good to cut up or throw away.paulusvrotius wrote:...You should try to repair your bonnet if possible....
and the bad part now is that i want to use the hump, but if this bonnet is so rare i'm most probably never gonna get the part that's missing
- zahistorics
Still worth fixing. Carefully undo the inner frame a from a 4 cyl bonnet and use that to do the repair.
The casting for the back is rare, but they are findable, more so in ZA than the UK.
The good news is that it is an easy to fabricate shape to make a replica bolt on bit from sheet steel.
- paulusvrotius1
I agree, not a hard shape to copy. Here's a few pics.
- DSCF3736.JPG (101.94 KiB) Viewed 3094 times
- DSCF3737.JPG (127.05 KiB) Viewed 3094 times
- DSCF3738.JPG (120.39 KiB) Viewed 3094 times
- DSCF3739.JPG (106.17 KiB) Viewed 3094 times
- DSCF3740.JPG (119.38 KiB) Viewed 3094 times
Advertise on Junkmail or Gumtree for the part you're looking for.Who knows maybe it pops up out of someones garage soon.....I saw one on e-bay not so long ago.
Johan Ras
Superformance Cobra with '66 FORD 427 Sideoiler
72 BG Capri Perana
81 Mk2 Escort 1600 Sport
74 Mk1 BG Granada Perana Coupe
75 Mk1 Granada XL Coupe
72 BG Capri Perana
I have one from an early Perana bonnet.
PM sent.
PM sent.
- zahistorics
Hello Magan! where have you been?Perana wrote:I have one from an early Perana bonnet. PM sent.
