Very lucky. Any updates on your project?427TNT wrote:Then i was lucky this week.I bought me another Toploader as a back-up this week for R3800.00.Also included was a clutch and pressure plate,flywheel,clutch master,clutch slave,yoke,speedo-drive fitting,shifter with linkages......IbanezRG wrote:ok so i've called Gillo engineering they ask R 2440 for the bellhousing to fit a cressida box... thats a lot. does anyone know where i can get it cheaper ? or is that the price they go for ? called around for gearbox aswell cheapest i could get was R 3500 for the cressida box since its the easiest to find . is that a ok price ?
V8 ford capri project
Re: V8 ford capri project
handed in the crank and heads at the engineers.. and when i turned around the one head i noticed that it has 302 written on it... so looks like i've got a 289 with 302 heads. i've read that thats not a good combination
ok got the stuff back from the engineers and went shopping for some parts.
now on the sump why is there a bog hole on the side ?
and i test sprayd the color, picture not so good. makes it look very light phone pic with flash on
car is ready for paint. i just need to make some time and make sure everything is 100%.
now i decided to install my automatic gearbox for now and change it one day when i earn more money. since this project is starting to cost me more than i had in mind. so i'll rather do that than to stall the project and never finishing it.
My plan was just to hone the block and keeping the standard pistons. Now after buying rings and honeing one celinder, I mesured the ring end gap and its 1mm a bit to much and the celinder walls are stil not smothe.. So the block is going to the engineers tomorrow morning. And I'll have to buy some oversize pistons and rings..
At least you have got the best 302 cylinderheads. Much better than the small 289 ones
Hole on the side can be used for oil temp sensor or block it of.
Good luck.
Good luck.
some updates. i'm busy putting the engine back together.
Looking good!
Good going there.Keep us updated with the progress.......
Johan Ras
Superformance Cobra with '66 FORD 427 Sideoiler
72 BG Capri Perana
81 Mk2 Escort 1600 Sport
74 Mk1 BG Granada Perana Coupe
75 Mk1 Granada XL Coupe
72 BG Capri Perana
- 73Ranchero
Shaping up nicely RG, hang in there and keep pics coming.
There's no substitute for cubic inches
Deon
Deon
Users browsing this forum: No registered users and 18 guests
