Ford Falcon XH Ute
Racer-X
Re: Ford Falcon XH Ute
Post by Racer-X » Sun 26 Feb 2017, 12:58
I have seen that one.
I don't want another one though.
It would be great to have a better base to start from.
As far as I know with rust, it never goes away.
Sent from my SM-G920F using Tapatalk
hanov0
Post by hanov0 » Sun 26 Feb 2017, 13:54
These cars known to have that particular problem. :(
I also had a starting issue last week, pulled out everything
Ended up ANTS got into my relays 8O :lol:
Hano'
Racer-X
Post by Racer-X » Sun 26 Feb 2017, 13:59
hanov0 wrote:These cars known to have that particular problem. :(
Do you mean rust?
Ya. My sills are non existent.
1 Bonnet hinge is attached to the body the other is not.
I also need a Windscreen.
hanov0
Post by hanov0 » Sun 26 Feb 2017, 17:42
NO , no the body module failure, or Smartlock.
Hano'
Racer-X
Post by Racer-X » Sun 26 Feb 2017, 17:47
hanov0 wrote:NO , no the body module failure, or Smartlock.
Ok,
The info i found here" http://www.tiperformance.com.au/knowled ... -problems/
Pinout: http://www.fordmods.com/ford-technical- ... mation-d89
Racer-X
Post by Racer-X » Sat 18 Mar 2017, 11:58
Hi
I have another issue:
No start.
Starter cranks but engine doesn't fire.
It has been starting 100% since I did the starter immobilizer bypass on the BEM.
Now it would seem that the other smartlock immobilizer option is preventing spark.
Also, just my luck, the only solution is import a ozzie chip or get another ignition barrel.
Any ideas?
(besides fire)
Racer-X
Post by Racer-X » Mon 17 Apr 2017, 18:51
Racer-X wrote:Hi
No start.
Any ideas?
(besides fire)
:lol:
I found the problem:
I had been fiddling with the radio as my friend who is using the vehicle installed a radio i supplied.
He wired it direct to the battery.
Long story short while i was fiddling i managed to short out the OEM ignition switched radio wire.
This 10A fuse (interior fuse box, top 2nd from right) is in line with the; radio, interior light,central locking & smartlock.
Basically there was no power to the Smartlock box. The starter was still turning and there was spark but no injector pulse.
That was fun. It took me 3 days to eventually discover that.
:D
Racer-X
Post by Racer-X » Thu 18 May 2017, 18:37
Small update.
I might be getting the rust repaired for a reasonable price.
Sent from my SM-G950F using Tapatalk
Racer-X
Post by Racer-X » Sun 18 Jun 2017, 09:30
Another update :
I am getting the rust repaired.
The door sills in both sides and the bottom of the a pillars on both sides.
I am looking for a Windscreen.
Yes. I know I can get one from Leon from classic windscreen for R4500.
That is of of my budget at the moment.
Racer-X
Post by Racer-X » Tue 27 Jun 2017, 09:21
Does anyone have any idea if the windscreen from the falcon Sedan (ef/el) from the 90's fits in the Ranchero (xh)?
I struggling to find a decent windscreen.
Users browsing this forum: No registered users and 28 guests
