Ford Falcon XH Ute
Re: Ford Falcon XH Ute
Post by ters » Tue 04 Oct 2016, 16:29
Racer-X wrote: However the Sedan manual I have says that color doesn't indicate condition. Sent from my SM-G920F using Tapatalk
Smell does, burnt toast?
Racer-X
Post by Racer-X » Tue 04 Oct 2016, 16:51
The old oil just smelt like old oil. No burnt smell.
I had my alternator checked today: 14.5v.
I repaired some of the wiring going to the alternator plug.
So I am about to refit and see if it works correctly.
BTW, any ideas on how to disconnect the central locking?
Racer-X
Post by Racer-X » Thu 26 Jan 2017, 20:37
Ok, it seems my motor and box are very tired. I am dreaming of a 1uzfe conversion with the lexus box and OEM wiring.
1 friend of mine agrees with me.
My other friend says i must use a Ford V8.
I have an adapter match a Cleveland to the Ranchero gearbox.
Now i am leaning towards the lexus due to the standard power levels and the relative cheapness of it.
It seems to me that the american v8's are expensive to buy and rebuild. Also the power levels are lower than the 1 uzfe.
Any advice?
Sent from my iPad using Tapatalk
Post by IndianaJones » Thu 26 Jan 2017, 21:36
I'm busy with a Lexus conversion, done well, it is not cheap.
If I were in your shoes, I'd rebuilt the Falcon six, and trans.
If you want more power, turbocharge it.
Racer-X
Post by Racer-X » Thu 26 Jan 2017, 21:40
IndianaJones wrote:I'm busy with a Lexus conversion, done well, it is not cheap.
Well, i was also thinking about that, but i understand that a std rebuild would cost about R15,000 for parts alone.
So i figure i could rather spend that an a lexus v8.
I have also thought that turbocharging might be fun.
lumi-fan
Post by lumi-fan » Fri 27 Jan 2017, 20:33
A proper Lexus conversion will leave you no change from R60k.
If it was my car, I'd go for a stroker 347 Ford V8
Sent from my HTC_M10h using Tapatalk
Racer-X
Post by Racer-X » Fri 27 Jan 2017, 21:03
lumi-fan wrote:A proper Lexus conversion will leave you no change from R60k.
What would the cost of that 347 be?
Leon
Post by Leon » Sun 12 Feb 2017, 23:35
Hi.
Awesome bakkies these, i have a 96 xr6 its not very quick but pulls like a ox.
Pricing would depend on what you have. I think rs performance or the v8 shop sell a 347 kit but you are still gona need a 302 motor to do the mod and you need to find a good engineering shop to help as i beleve there are clearance issues where the lower block needs to be ground to take the stroke. Im not sure if you need the block decked aswell?
Good luck to you on this.
Leon.
Racer-X
Post by Racer-X » Mon 13 Feb 2017, 07:43
Hi Leon
I am leaning towards doing a 3uz conversion.
My brother just bought a 1975 Ford Falcon XB ute (1975 Ford Ranchero 500)
It has a Ford 351 Cleveland in it.
It's epic.
Though i think i would like a v8 that revs higher.
Racer-X
Post by Racer-X » Mon 13 Feb 2017, 10:15
Here s the Xb, apparently a member in this forum used to own it;
