Ford Falcon XH Ute
Re: Ford Falcon XH Ute
Post by ZA Perana » Sun 25 Sep 2016, 18:31
As far as I know only the XR6 got the LS diff.
Racer-X
Post by Racer-X » Sun 25 Sep 2016, 18:33
ZA Perana wrote:As far as I know only the XR6 got the LS diff.
Thanks.
That would mean hopefully that my diff is working when it spins one wheel.
Sent from my iPad using Tapatalk
Post by IndianaJones » Mon 26 Sep 2016, 14:19
The first 2 photos are of a 1997 Ford Ranchero Outback, currently for sale on OLX...
The parts diagram, is a printout I received from my local Ford dealer today, depicting both the standard differential unit and the Hydratrak.
Racer-X
Post by Racer-X » Mon 26 Sep 2016, 19:31
That is interesting.
Thanks.
I must study it.
Racer-X
Post by Racer-X » Sat 01 Oct 2016, 07:28
I seem to have developed an odd issue.
Periodically if i am cruising along in drive at about 60 km per hour, the rpms jump up as if the gearbox in neutral.
Then i have to shift into 3rd then play with the accelerator pedal until it shifts into gear again.
Or another thing it does is stay in 1st or 2 nd gear and wont shift up until i do the same fiddling procedure.
I havent changed the gearbox oil and the level is correct.
Shaunp
Post by Shaunp » Sat 01 Oct 2016, 14:56
I would change the oil n check the cooler. Maybe flush the cooler
Magic happens.
Racer-X
Post by Racer-X » Sat 01 Oct 2016, 18:06
I am planning to dot that.
According to the sedan manual: I need 10 litres of Castrol TQ95 automatic transmission oil.
I phoned my local Midas and they say they don't have that but according to their specs i can use Castrol Dextron 2.
This will be R395 per 5 litre.
The the autobox oil filter is available from my local Ford Dealership.
2 days to arrive.
+-R1400.
Needless to say i don't think i am going to buy the filter form the dealer.
Racer-X
Post by Racer-X » Tue 04 Oct 2016, 15:38
I bought some oil.
Castrol dextron 2
Drained the old oil.
Cleaned filter.
The stealer wanted R1400 for a new one.
Then refitted and filled with fresh oil.
It is still doing the odd shifting into neutral and staying in low gear. I suspect it might be voltage related.
Sent from my SM-G920F using Tapatalk
marnus
Post by marnus » Tue 04 Oct 2016, 16:15
Isn't that oil suppose to be pink/redish..?
Its my understanding that an auto box with brown to dark oil has burned a clutch or a couple..
Racer-X
Post by Racer-X » Tue 04 Oct 2016, 16:18
marnus wrote:Isn't that oil suppose to be pink/redish..?
Correct
The oil that went in is now red .
However the Sedan manual I have says that color doesn't indicate condition.
Makes no sense to me
