Shocks for 1969 barracuda
I've been searching and found nothing....not Gabriel ,not Monroe...everwhere I ask ,they look at me as if im speaking mandarin!!Can anyone tell me where can I get shocks for my cuda...or do have too import!!thx
Re: Shocks for 1969 barracuda
Do you have a pic,I have some old school shocks,also guy at piston ring with some...
Go direct to Gabriel and give them your original part numbers. They were able to supply compatible shock part no,s. for my 65 MalibuWillievanwyk wrote:I've been searching and found nothing....not Gabriel ,not Monroe...everwhere I ask ,they look at me as if im speaking mandarin!!Can anyone tell me where can I get shocks for my cuda...or do have too import!!thx
Contact HENNIE 0834553545 - he had a stack of new Valiant shocks - not sure if they are the same for all models.
I believe all Mopar A bodies built around the world (1960-81) use the same replacement front/rear shocks...........I know ours here in the USA are the same from 1960-76, when the those cars were discontinued.Hubcap wrote:Contact HENNIE 0834553545 - he had a stack of new Valiant shocks - not sure if they are the same for all models.
Bearhawke in Az, USA
1998 Plymouth Grand Voyager minivan.
About 2 or 3 years ago i struggled to find shocks for my then Valiant Charger - somebody recommended shocks off a Toyota Hilux (probably earlier models) and fitted perfectly. I just forgot the part number, but if you take your old shocks to any spares as samples, they should be able to find you the closest that can match your Cuda Shocks.
Fanks all,i went too a local Midas and just went through their stock and matched mine too something similar....found gabriels 45171 for the front and Armstrong 320830 on the back..Works good
Users browsing this forum: No registered users and 12 guests
