Johann66
Post
by Johann66 » Sat 16 Dec 2017, 18:47
Just when all is supposed to be OK!
I'm having starter issues for some time now and took out the starter to check why the Bendix does not kick-in immediately! I replaced the solenoid as had cracks in the head! I fitted a new solenoid and tested the starter on the bench! Unit works perfectly!
Problem
The starter does not engage the ring gear! It just clicks as if it is against the gear! It does not want to mesh!
Took it out, tested again, working well, Seems to jam when fitted!! Can somebody give me advice as to possible answer to my problem please!
- Ring gear
- DSCF3662.JPG (207.85 KiB) Viewed 8471 times
- Note Bendix forward and back!
- DSCF3663.JPG (272.57 KiB) Viewed 8471 times
- Strong action!
- DSCF3664.JPG (232.06 KiB) Viewed 8471 times
barrydorr
Post
by barrydorr » Sun 17 Dec 2017, 20:07
Not sure what could be your problem, but nice to see an update on the record! I am sure with you knowledge you will figure out the issue with the starter
My Toys:
1974 Opel Manta 1900 DL
2008 Mitsubishi Outlander
Johann66
Post
by Johann66 » Mon 18 Dec 2017, 15:05
barrydorr wrote: ↑Sun 17 Dec 2017, 20:07
I suspect the coat of paint at the housing is causing a poor connection! I cant believe that the starter is so strong and takes immediaterly! and when fitted, not alive!! Fitted ignition switch with separate wiring and its perfect!! on the vice! and clicks only when fitted! Will try to remove all the paint down to the metal! Try again! Will take pic ASAP! Need to wash! Spot and Fog lights fitted!
- Red Paint!
- DSCF3661.JPG (215.16 KiB) Viewed 8439 times
Scorpionman
Post
by Scorpionman » Mon 18 Dec 2017, 18:27
Check the earth strap from engine to body. I had a situation. Once where my clutch cable became hard and the car did not want to start when hot. Cold engine no problem. End of the day the woven earthstrap from body to engine was bad. The engined earthed through the clutchcable which melted the plastic liner in the cable which did not work well with a moving cable. Removed the started numerous times and tested it. Worked fine. New earth and cluth cable and everything was fine.
1961 Alfa Giulietta Sprint
1971 Fiat 124 BC Coupe
1975 Fiat 132 GLS
Johann66
Post
by Johann66 » Tue 19 Dec 2017, 15:06
Scorpionman wrote: ↑Mon 18 Dec 2017, 18:27
Thanks for the advice! Fitted extra earth cable to engine block! Also fitted spacers to starter! Charging battery, lets hope!!
Johann66
Post
by Johann66 » Sat 23 Dec 2017, 18:04
Johann66 wrote: ↑Tue 19 Dec 2017, 15:06
Check the earth strap from engine to body. . New earth and clutch cable and everything was fine.
Played with shims and the Extra earth cable! stronger current and the starter took better! The shims allowed the Bendix to engage without clicking!
Immediate turning! Problem solved!
Johann66
Post
by Johann66 » Fri 29 Dec 2017, 17:37
Got Mobile! Got a birthday present for the Opel! Spot and Fog lamps! Car needs serious wash & clean up!
- Complete with relays
- DSC_0003.JPG (432.74 KiB) Viewed 8357 times
Johann66
Post
by Johann66 » Sat 30 Dec 2017, 16:20
This is a real Barn Find in Mpumalanga!! This is the 1966 Opel Rekord L that carried the first 36DCD Weber and inlet manifold, Also carried disk brakes and booster All that this car requires is a good valet and the repair of the driver's seat.
No Rust or respray required, This car is pristine and every thing works! All that is required is a battery and tyres
Look and enjoy the as found look. Going for a wash tomorrow
20 September 2013!!! Bright Eyes!! Still busy after all these years!!
- As at 30 Dec 2017,
- DSC_0001.JPG (441.51 KiB) Viewed 8339 times
Post
by RASSIE » Sun 31 Dec 2017, 09:26
On Facebook!
Wesley van den Heever added 7 new photos.
Yesterday at 8:58am ·
BARGAIN BARGAIN!!!!
RESTORED 1968 OPEL REKORD
1.9 STRAIGHT 4 motor. Manual column shift.
ONLY R60 000 (Slightly Negotiable)
Vehicle is 99.9% completed, front to back, even factory spec colour. License is up to date but must still go for roadworthy. Just shorts suspension bushes and under carriage must be painted. Besides that, bumper to bumper, you name it, it's been done. Owner has spent more than the asking price on the vehicle and has the invoices to back it up. Owner has fallen ill, so sadly he wont be finishing it. His reason for not painting the under carriage yet is to show there is no rust hidden. This car is clean as a whistle, a real beaut and a steal at this price.
Johann66
Post
by Johann66 » Sun 31 Dec 2017, 13:53
RASSIE wrote: ↑Sun 31 Dec 2017, 09:26
On Facebook!
BARGAIN BARGAIN!!!!
Hullo Rassie. I think my Rekord is worth as much and has become my daily driver!!
