1949 Hillman
Stealth GT
1949 Hillman
Post by Stealth GT » Mon 18 Aug 2008, 17:33
Hi all
Im looking for some specs on a 1949 Hillman 4 cylinder engine the specs I am looking for are as follows : Big ends & mains STD journal sizes,STD Cylinder bore size, as well as all the Torque settings
Thanks Warren
zahistorics
Re: 1949 Hillman
Post by zahistorics » Mon 18 Aug 2008, 23:52
Warren,
Maybe these will help...
Manual for sale on ebay http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0267166674
The Hillman Owners Club http://www.motorbase.com/contact/by-id/762 - I'm sure if you ask them nicely the can put you in touch with someone
Hubcap
Re: 1949 Hillman
Post by Hubcap » Wed 20 Aug 2008, 08:42
Hi
Checked through my old catalogs and stock and came up with the following:
Std bore on this is 63mm.
Con rod big ends - std size 41.262mm on crank and 43.942 housing
Mains - std size 44.437mm on crank and 48.146mm housing
I have mains available in 40 and 60 thou, and big ends in 10 and 20 thou. Should also have gasket sets in stock.
If interested give me a call on 082-802-5520
Hubert
Stealth GT
Re: 1949 Hillman
Post by Stealth GT » Wed 20 Aug 2008, 18:14
Thanks Hubert
I will measure up tomorrow and get back to you
Warren
zahistorics
Re: 1949 Hillman
Post by zahistorics » Wed 20 Aug 2008, 20:51
I am amazed at this forum! Ask just about anything and someone has the answer.
Stealth GT
Re: 1949 Hillman
Post by Stealth GT » Wed 20 Aug 2008, 21:01
I have to agree
Warren
zahistorics
Re: 1949 Hillman
Post by zahistorics » Wed 20 Aug 2008, 22:03
Determining unknown torque settings
My dad's tip from many years ago when he was a motor mac (he is 80 on Friday, so that is many many years ago) .
Use a click type torque wrench. Turn the setting down low say 20 lb/ft. Even lower if it is a tiny nut/bolt or holding together alloy parts, or has a thick cork gasket.
Try to undo the nut/bolt. Should click before it moves. Adjust the click up by about 2 lb/ft. Repeat. After 30 lb/ft step by 5 lb/ft. Repeat until nut/bolt just starts to move - that's your torque setting for reassembly.
Of course this does not help if things are severely rusted, or it is already stripped, or has been assembled by fools whose idea of tight is either:
1. Finger tight plus a quarter turn.
or
2. Net voor hy strip.
