Cobra information
Any discussions about the history of the road going cars
pietpetoors
Cobra information
Post by pietpetoors » Thu 06 Jun 2019, 20:05
I bought a used Cobra which I am busy fixing.
The Reg papers says Cobra Venom RT
I contacted Johnspeed Cobra and he said the chassis is probably one he built for Venom but they built their own bodies.
I am looking for a wiring diagram.
The harness is neatly numbered, but I do not know which is going where.
On the fuse box is a contact number which does not exist no more, 012-808-0558
I also need information about this wiper motor. Is a Lucas, does anybody maybe know what vehicle it came from?
Any help on this vehicle would be much appreciated. It was first registered in 2012.
Wiring
cobra-fix (1).jpg (255.05 KiB) Viewed 5877 times
Wiper
cobra-fix (4).jpg (270.43 KiB) Viewed 5877 times
Wiper
cobra-fix (3).jpg (230.92 KiB) Viewed 5877 times
Cobra
Pieter-Cobra (2).jpg (386.83 KiB) Viewed 5877 times
Pieter Cobra
Pieter-Cobra (3).jpg (394.69 KiB) Viewed 5877 times
Cobra
Pieter-Cobra (5).jpg (380.07 KiB) Viewed 5877 times
Only Dead Fish Go With The Flow!
bmwmaniac
Re: Cobra information
Post by bmwmaniac » Thu 06 Jun 2019, 20:55
that wiper setup looks like the generic system fitted to many British cars, prob most popular here on the old mini's.
"If you park your car, walk away and don't look back, you're driving the wrong car"
KSF
Post by KSF » Fri 07 Jun 2019, 16:20
Cobra's generally used the Jaguar wiper assembly, but as said, generic to older British Leyland cars. Also popular here in the older Land Rovers.
pietpetoors
Post by pietpetoors » Fri 07 Jun 2019, 18:43
Took the wiper motor appart today, seems like I will manage to fix it. Just all the old grease are so sticky that it can hardly turn and it needs new brushes.
Scorpionman
Post by Scorpionman » Sun 09 Jun 2019, 15:48
When rebuilding the wiper motor you can also check the small gearboxes at the wiper mounts. That grease gets hard too that can cause stripped teeth on wiper mount
1961 Alfa Giulietta Sprint
1971 Fiat 124 BC Coupe
1975 Fiat 132 GLS
