Hi William,
May I ask a huge favour of you ?
I recently rebuilt my FMX and got everything 100 % except the front band adjustment.
One book tells me turn in the screw 3/4 turns and another one says 1 turn.
I tried feeler gauges, and then a 6.35mm thick spacer (piece of metal), but I found that both turned as I tried to tighten the screw to 10 in-lbs, as instructed.
My 1st to 2nd gear shift is, as suspected, not 100%.
Would you please tell me how exactly you set the gap, and how many turns do you make. How tight is too tight ?
Luckily I fitted a drain plug so taking off the pan again will be a simple tidy job.
I sincerely hope that you enjoyed the humour and that it helps you with rebuilding your life.
Like FairmontGT, I also split something from laughing.
Anyway, I hope you enjoy the humour below.
Q1. In which battle did Napoleon die?
* his last battle
Q2. Where was the Declaration of Independence signed?
* at the bottom of the page
Q3. River Ravi flows in which state?
* liquid
Q4. What is the main reason for divorce?
* marriage
Q5. What is the main reason for failure?
* exams
Q6. What can you never eat for breakfast?
* Lunch & dinner
Q7. What looks like half an apple?
* The other half
Q8. If you throw a red stone into the blue sea what will it become?
* it will simply become wet
Q9. How can a man go eight days without sleeping ??
* No problem, he sleeps at night.
Q10. How can you lift an elephant with one hand?
* You will never find an elephant that has only one hand..
Q11. If you had three apples and four oranges in one hand and four apples
and three oranges in the other hand, what would you have ?
* Very large hands
Q12. If it took eight men ten hours to build a
wall, how long would it take four men to build it?
* No time at all, the wall is already built.
Q13. How can u drop a raw egg onto a concrete floor without cracking it?
*Concrete floors are very hard to crack
Hi Alida, congratulations on the start of a new relationship.
I sincerely hope that it works out and brings you total happiness.
