V8 Shops in Gauteng, West Rand?
BIGSIX
Post by BIGSIX » Thu 21 Oct 2010, 10:10
Hi All,
Do any of you know where in the West Rand there are V8 shoppes for spares and accessories?
I know of RS performance and US Connection, are there any other and contact info if you have.
Old Ford's don't Die, they just go Faster!
Hi, my name is Johan and I am a V-addict!
'97 Suzuki TL1000S - V2(SOLD)
'76 Ford Cortina XLE Bigsix 3.0 - V6
'90 Ford Sapphire 3.0 GLX - V6
'97 Mazda MX6 2.5i - V6
'96 Ford Courier D\C 350 16v - V8
LeonardZeiler
Re: V8 Shops in Gauteng, West Rand?
Post by LeonardZeiler » Thu 21 Oct 2010, 10:18
V8 Shoppe in Alberton.
BIGSIX wrote:Hi All,
[align=center]Image[/align]
Insomnia
Post by Insomnia » Thu 21 Oct 2010, 10:19
Would depend what you are looking for.
I do not know any V8 Specific shops on the west rand.
BIGSIX
Post by BIGSIX » Thu 21 Oct 2010, 11:12
I am looking for a shop closer to me to get a HEI or electronic distributor for my 350.
My Bakkie runs great but as soon as you hammer it for a few seconds the coil starts fouling and overheating.
Bakkie run on all 8 at full tilt and then it just dies completely or starts firing on 6 or 4 cylinder.
First I though it was the carb overheating, so I closed the exhaust port running through the intake, still same problem so I changed the Black Coil to a new Bosch Blue High output Coil, Worked better for the first 3 runs then started to do the same thing. So I am know looking at getting a Electronic Distributor to see if that will sort the problem.
Elcamino
Post by Elcamino » Thu 21 Oct 2010, 12:27
Spitronics sells them for R1200 as advertised in the S&S try and get to a agent in your area.
Mine is electronic with a Mag Convertor and it runs well.
Just had to fit a TP100 for the Dictator ECU
1974 Chevrolet Elcamino 350CI 220Rochester TBI
2010 BMW 335I Full house Sports pack
Tony69
Post by Tony69 » Thu 21 Oct 2010, 12:39
Check you plugs wires. If they've got a slight resistance, this resistance may increase as temp increases. Do your leads get hot as well?
BIGSIX
Post by BIGSIX » Thu 21 Oct 2010, 14:01
Will Check the leads this afternoon when I get home!
hanov0
Post by hanov0 » Thu 21 Oct 2010, 14:54
Try American Powersport (Pty) Ltd T/A Berlin Autotronics.. http://www.us-powersport.co.za
51 Gerhardus St Strijdom Park
Hano'
lemuel
Post by lemuel » Mon 25 Oct 2010, 13:06
You can come see us, we are located in Roodepoort, can get your anything U need, new or used, check out the website at www.lemuel.co.za
Always glad to help
BIGSIX
Post by BIGSIX » Mon 25 Oct 2010, 14:02
lemuel wrote:You can come see us, we are located in Roodepoort, can get your anything U need, new or used, check out the website at http://www.lemuel.co.za
Always glad to help
I will give you a shout next time to see if you can help, I am still waiting to hear if you have a 38 Weber butterfly throttle gear(the gear that works the first butterfly and runs on the second one to open. I asked about it a few months back and you guys were going to let me know if you found anything?
Users browsing this forum: No registered users and 26 guests
