I'm thinking about ripping the TPi off my car and replacing it with Edelbrock Performer intake with Holley carb and vacuum advance MSD distributor.
The main reason is I'm getting fed up with slightly odd issues on my car. Like slightly erratic throttle pickup when pulling away (like a small stutter / non smooth power delivery) plus when it's properly hot (after about 20 miles of driving) it won't rev past 4,500 rpm, it's like there is a rev limiter but only after driving a reasonable distance.
In the last year (to sort other problems) I've changed all eight injectors, fuel pump, fuel filter, air filter, TPS sensor, PCV valve, temperature sensor (both of them), dizzy cap, rotor, plugs, HT leads, ignition module. Air is removed as is the charcoal canister. I have a new O2 sensor to fit, which 'may' help and I'll try shortly. The only other thing I can think of is a bad chip / program or throttle body. But to buy these from the states will cost as much as all the parts needed to go over to a carb, so I'm starting to think I may as well ditch all the sensors / injection and make the leap, at least that's easier to fix and gives more power per dollar.
Any view / thoughts / experience on changing over to carb or what my problem may be with the current injection setup? Or can anyone provide a decent ECU with reprogram to take into account the exhaust / filter / air removal? Some time later in the future I will also change heads / cam as well.
The car is currently standard other than full twin exhaust, K&N filters and some kind of ECU flash by a previous bodger (sorry owner!). It's a 1991 5.7tpi.
TPi to Carb Conversion - views?
Re: TPi to Carb Conversion - views?
Welcome! Vehicle, model year etc?
That Ecu flash may be the issue ... Where are you from ?
Users browsing this forum: No registered users and 21 guests
