Why Rassie is slow.
Why Rassie is slow.
My leg has cost me plenty with doctors and medication. I spend 2 days at a Public "black most “hospital and getting better results. Waiting was the only problem. My legs got no return blood flow and water also build up. I am far behind on work. Yesterday I got good advice and medication. Both legs outer valves stop working and causing an ulcer on the left leg. I got for R.20 good advice and medication, but need to wear socks 24/7 to compress both legs for water and blood flow.
This is very new to me as I am very active.
Take note my work will be slow but still 100% up to standard.
- 20161204_152007.jpg (78.26 KiB) Viewed 5504 times
- 20161204_152201.jpg (67.39 KiB) Viewed 5504 times
- 20161118_110018.jpg (59.22 KiB) Viewed 5504 times
- 20161120_084910.jpg (62.31 KiB) Viewed 5504 times
Re: Why Rassie is slow.
Rassie are you using "Spieracten" I have no more swelling of the legs! I take them morning and afternoon.
went from 4 tablets to 2 after reduced swelling!!
My legs used to look like that!!! Bloody bitter tablets!!
Hang in there, hope you get better soon.
Thanks I am using "Spieracten" but no luck. I am now with Des Chem as they got very professional nurse/ sisters. I was with them and will see in the morning what they say. The medication plaster is pulling all the junk out of my leg. Just hope it work as it burn like fire and the socks cover all.
I am with the same franchise but have been with my local chemist for 40 yrs! They have accepted Dis Chem as their new franchise!RASSIE wrote:Thanks I am using "Spieracten" but no luck. I am now with Des Chem as they got very professional nurse/ sisters. I was with them and will see in the morning what they say. The medication plaster is pulling all the junk out of my leg. Just hope it work as it burn like fire and the socks cover all.Rassie.
Sterkte!!
Oom Johan they are very good and not play when it came where I can loose my leg. I have seen them Tuesday and they remove the special plaster and fit a stronger one to get all the junk out of my leg. I also have to wear 2 compression socks as soon as I get out of bed where my feet have to be lifted on 2 pillows at night. The pain is just unbearable. Friday I must be back and Monday they want to see me again. They do not play if it is serious. Once the wounds are clean they will look at the damage and treat it from there.
Lets hope and pray that the recovery is well!!RASSIE wrote:Oom Johan they are very good and not play when it came where I can loose my leg. I have seen them Tuesday and they remove the special plaster and fit a stronger one to get all the junk out of my leg. I also have to wear 2 compression socks as soon as I get out of bed where my feet have to be lifted on 2 pillows at night. The pain is just unbearable. Friday I must be back and Monday they want to see me again. They do not play if it is serious. Once the wounds are clean they will look at the damage and treat it from there.
Thanks Oom Johann it is a scary story to loose a leg as I need them both as I got plenty work to complete and no pension. My hands put food on the table.
I pray the Lord will help me.
Sterkte Rassie, wish you a speedy recovery! You and your family are in our prayers.
Thanks Punch.
Users browsing this forum: No registered users and 28 guests
