Classic Mercedes advice.
chevy4ever
Post by chevy4ever » Fri 12 Aug 2011, 08:17
Hi
I’m currently doing some work on a friend’s 1970 Mercedes 250CE, fuel injection model.
It has an annoying problem of surging badly at low speeds. You have to keep the revs up in order to get it going.
I have just taken it in to have the injectors serviced. But it did not cure the problem. :?
The other problem - It has the tendency of shaking its rear when driving above 40mph. actually feels like you driving in/thru ruts in the road.
Any advice or know where I can find a classic Mercedes mechanic would be greatly appreciated.
Ty
REMEMBER A CLEVER MAN KNOWS ALL THE WAYS....
BUT A WISE MAN KNOWS THE RIGHT WAY
First V8
Re: Classic Mercedes advice.
Post by First V8 » Fri 12 Aug 2011, 08:51
Hi Ty , I know of a very good Merc mac up here in Gauteng .He did work on my 280E Auto and i have never seen such attention to detail before . He of course is German . :)
Rudy
2010 Chev Lumina SS
1968 Chevy Impala (SOLD)
1968 Vw Beetle ( SOLD)
1963 Mini Pick Up ( Exported to UK )
chevy4ever
Post by chevy4ever » Fri 12 Aug 2011, 10:05
First V8 wrote:Hi Ty , I know of a very good Merc mac up here in Gauteng .He did work on my 280E Auto and i have never seen such attention to detail before . He of course is German . :)
Rudy
Hi
Thanx. Please can you pm me his contact details. Our local merc guy (PMB) said the 250CE is to old for him...
Ty
mahleu
Post by mahleu » Fri 12 Aug 2011, 13:27
I know a very good mechanic in Queensburgh, reasonable as well.
That's how I roll. Down the hill 'cause the car won't start and the brakes don't work.
LeonardZeiler
Post by LeonardZeiler » Fri 12 Aug 2011, 18:33
Howdy bud.
Sounds indicative of a vacuum leak to me, if you floor it, does it seem to be ok.
Vacuum leaks can be tested with a can of carb cleaner, sprayed around the pipes and gaskets, if you have a leak, it will be sucked in, and you will hear the additional liquid explode, ie engine noise will change, that means you have a leak.
As for the wobbly bits, sounds like rear diff mount(s) or control arm bushes. A good tug/pull/wabble the crap out of with a large something... will give you an indication.
Pity your so far away, I would of been able to help ya find the issue.
[align=center]Image[/align]
First V8
Post by First V8 » Fri 12 Aug 2011, 20:20
Us BOKSBURG okes have all the answers . ;) ;) :lol:
2010 Chev Lumina SS
chevy4ever
Post by chevy4ever » Fri 12 Aug 2011, 20:21
LeonardZeiler wrote:Howdy bud.
Hi Leonard
Thanx for the reply. The car pulls fine when it’s driven above 80kmph or when the revs are kept high. However I did notice this afternoon, the surging is almost gone when the car is cold, but gets bad when it’s at operating temp.
As for the vacuum, I coupled up the gauge on the port to the brakes; it took a long time to get up to pressure. Will try the carb cleaner, thanx for the tip.
The car still has the original oil bath filter, don’t know if I should keep it or change it to the cone type filter???
Will check the suspension out. Personally I think the old merc doesn’t like the big tyres (225/45 R17).
Ty
chevy4ever
Post by chevy4ever » Fri 12 Aug 2011, 20:25
First V8 wrote:Pity your so far away, I would of been able to help ya find the issue.
Boksburg???? Where's that... :lol: :lol:
just joking. Thanx a mill.
