Hi All,
On my 350 V8 I am still running distributor with points and my Coil is packing up(black coil not sure what make), I am looking at getting a Bosh Blue Coil as the other coils RS performance and the other V8 Places have are for electronic distributors.
I need the Bakkie fixed now so I just want to replace the coil and I will get a Electronic distributor system in December or so.
If your still have the point distributors, what coil are you using?
Bosch Blue Coil any good?
Old Ford's don't Die, they just go Faster!
Hi, my name is Johan and I am a V-addict!
'97 Suzuki TL1000S - V2(SOLD)
'76 Ford Cortina XLE Bigsix 3.0 - V6
'90 Ford Sapphire 3.0 GLX - V6
'97 Mazda MX6 2.5i - V6
'96 Ford Courier D\C 350 16v - V8
Re: Bosch Blue Coil any good?
If you are running stock points , you need a coil with the ballast resistor inside like the original black coil . Unless you add an external ballast resistor, running the wrong coil could fry your Points .v8 performance shops should have a Petronics coil, called the "Flame Thrower"
Bosch Blue coil (Brazil)Part no 0 221 119 027
The one I got is the Bosch Blue Coil Part 0 221 119 027, so it will work!(hopefully!!!)
Thanks for the info!
