Oil for 350 Chevy and 350 Turbo Box
Hi All,
Just wondering what oil you guys use on your V8 and Auto Gearbox.
I need to service my Bakkie in about a months time and need some input please!
Old Ford's don't Die, they just go Faster!
Hi, my name is Johan and I am a V-addict!
'97 Suzuki TL1000S - V2(SOLD)
'76 Ford Cortina XLE Bigsix 3.0 - V6
'90 Ford Sapphire 3.0 GLX - V6
'97 Mazda MX6 2.5i - V6
'96 Ford Courier D\C 350 16v - V8
Re: Oil for 350 Chevy and 350 Turbo Box
Hi I bought oil from RS PERFORMANCE.
Give them a ring.
Also there was a old thread aboit oil. Some guys is using Diesel engine oil. Rotella . The red container, think viscosity of 20w40. Seeing as cast iron blocks have higher heat than most modern aluminum engines. The diesel oil is better suited to cast Iron blocks.
Not sure about Auto boxes. I use normal Red ATF.
Give them a ring.
Thanks,
Phoned RS and they have a oil that they had made up with some extra additives, they said the only other oil that I should use is Shell Rimula R3X as it still has most of the additives in that the V8 needs.
Will be checking the local spareshop for the oil.
If its for a chev, dont bother, itl just leak out anyway....
80 Hatchback Ghia
80 Hatchback 302w
82 Hatchback Ghia T-Top
80 Hatchback 302w
If it's a Ford, cooking oil is as good as any
Funny after i typed that i just knew that you were going to post something there
80 Hatchback Ghia
80 Hatchback 302w
80 Hatchback 302w
Not as funny as a Ford with a Chevy motor though
It will be changed....... SOON
80 Hatchback Ghia
80 Hatchback 302w
80 Hatchback 302w
I just knew that the Ford vs Chevy banter was on its way!!
What's the service intervals for the V8's, every 15000km, 10000km or 5000km??
Id say 1st option for Ford and 3rd option for a chev
80 Hatchback Ghia
80 Hatchback 302w
80 Hatchback 302w
Users browsing this forum: No registered users and 21 guests
