Hi Guys
How do I identify a Ford 9" diff and what would a good ratio be for a 460 with C6 auto box, thanks.
Diff query
Diff query
'Spent almost all on a Mustang and a 72 Ranchero, the rest I wasted'
- PeteLeathersac
Re: Diff query
~ Pete
CANADA
CANADA
Re: Diff query
Your best ratio will depend on a lot of things , the wheels and tyres , stall speed of the box , the engine characteristics , intended use of the vehicle , wheter you intend to use an overdrive box in the future etc, weight of vehicle etc.
In general , you would find a ratio from 3.25 to 3.5 will give you the best compromise between acceleration and top end , under that will give you better long distance fuel consumption , over that and adding a 2000 stall will give you violent accel and a hugh revving highway speed.
I was running a 3.75 with a 454 and a 9" diff , 295/50/15 tyres - 1500kg vehicle , no stall and it was quite irritating. Considering I was at 280 kw and 700nm torque and a 6000 rpm engine , I went down to a 3.0 , the huge torque of a Big Block coped well , I lost 0.1 sec on the quarter mile , but highway driving was way more relaxed and fuel useage went down.
The nicest thing about smacking your head against the wall is........the feeling you get when you stop!!
05 Jag S-type R - supercharged v8
95 C4 lt1 corvette
RIP
95 C4 lt1 corvette
RIP
- OldSkool II
Re: Diff query
howzit72 Stang wrote:Hi Guys
3.25 would be a good allrounder
to identify
cant get to the bottom 2 bolts with a ratchet and extension
must use a spanner
Driving a 10 sec Honda is like coming out the closet
At first your friends are in awe, but you still gay
- j1autotech
Re: Diff query
As OldSkool says the bottom two nuts can only be loosened / tightened on a 9" with a spanner. A Ford 8" can be reached by a socket set like the rest of the nuts on the diff centre.OldSkool II wrote: to identify
must use a spanner
Hope these pics help out.
J1
This is a 9" rear end showing the two nuts that can only be worked on by a spanner
This side shot shows the 9" pinion carier getting in the way of using a socket set
This is an 8" rear end showing how the two nuts on the bottom of the carrier can be worked on by a socket set
Re: Diff query
Thanks for all the feedback guys, great help
Users browsing this forum: No registered users and 16 guests
