Need help with 38 weber jetting on my Sierra. Did some work on the motor after 700k kms - RJ cam, bigger valves, unleaded. Can't seem to get the jetting right - fiddling is driving me insane. Sluggish below 2500 rpm = bigger idle jets? Runs out of breadth at 4500 rpm. Idle jets current 55s, mains 137 air 180 - rest is what it was at assembly time. Any suggestions?
'Normal' driving not too bad ... but every once in a while hooligan mode kicks in and it is WOT ...
Any suggestions will be most welcome.
Weber carb jetting
Weber carb jetting
I'm not a complete idiot, some parts are missing
Ford Sierra V6
AC Cobra V8
Ford Sierra V6
AC Cobra V8
Re: Weber carb jetting
get modern technology on your side. fit a wideband lambda probe and guage.
Hi Getafix,
I am running 145 mains and 210 air with 55 Idle and a 55 spray.
just check what spray jet you have and that's the one that sprays through on both sides.
also check your lifter clearances as this can take out some power if not right.
Let me know if you get it right as mine is not 100% yet!
Old Ford's don't Die, they just go Faster!
Hi, my name is Johan and I am a V-addict!
'97 Suzuki TL1000S - V2(SOLD)
'76 Ford Cortina XLE Bigsix 3.0 - V6
'90 Ford Sapphire 3.0 GLX - V6
'97 Mazda MX6 2.5i - V6
'96 Ford Courier D\C 350 16v - V8
Mains 145 and air jets 185 and she will run super fast!!
I will try that this weekend as well.
Thanks Rassie!
Thanks Rassie!
Tried the 185 airs the weekend and not as good performance as the 210 airs. Might be because we are a bit higher up than you Rassie?
Switched my carb settings to 142 Mains 210 Air with a 70 Spray. Works well for me not sure if it might work on another motor or carb.
Just my 2c!
Just my 2c!
Thanx Rassie,
Will try this very soon. Carb City the only place to get jets and only Monday thru Friday.
Ford Sierra V6
AC Cobra V8
Ford Sierra V6
AC Cobra V8
Did the jetting 145 mains - 210 air. Top end much better. Still got a bit of 'hoes en proes' from standstill - comes alive at about 2500RPM - then it is 'hou vas!!!'
Ford Sierra V6
AC Cobra V8
Ford Sierra V6
AC Cobra V8
Users browsing this forum: No registered users and 20 guests
