Mopar: Is this for EGR?
Hi,
I'm not clued up with all things Mopar yet and was wondering if these connections/ports relate to the exhaust gas recirculation system?
If not, what are their purpose?
His: '05 WRX STi, '94 1.8t Caddy, '79 Golf LS, '76 Dodge D100 383, '74 Datsun 1200 ute
Hers: '10 Mitsubishi Outlander
Re: Mopar: Is this for EGR?
The center small port is part of the exhaust cross-over to heat the carburetor and work the choke in very cold climates. Suggest leaving the gasket cross-over tab intact, blocking the passage, as we live in warm climate and don't need it.
The top hole is ported vacuum, that normally goes to the brake booster.
(O O {]{]{]||[}[}[} O O)
Thank you, makes sense.
Where can I get a gasket, or are they readily available?
- Moering Tool
How does PCV work on these engines? Where does that go?
(Or doesn't it ? )
(Or doesn't it ? )
George @ US Connection in Wynberg is the guy for Mopar stuff. Normally they have stock.porno_ster wrote:Thank you, makes sense.
The Positive Crankcase Ventilation System is to siphon off blow-by vapors in your block. The pcv valve is normally fitted on one of the valve covers, and that ideally should feed to the big ported vacuum pipe in the base plate of the carburetor. If there is no pipe in the base plate, a "T" can be fitted to the ported vacuum hole.Moering Tool wrote:How does PCV work on these engines? Where does that go?
(Or doesn't it ? )
Cool, thanks.Mopar 440 wrote:George @ US Connection in Wynberg is the guy for Mopar stuff. Normally they have stock.porno_ster wrote:Thank you, makes sense.
As Simon says. George will have Felpro Valley-pan gaskets. You can get a gasket with heat risers blocked off, or DIY. Did mine myself...ads a couple horsies, and exhaust note deeper to .Mopar 440 wrote:The center small port is part of the exhaust cross-over to heat the carburetor and work the choke in very cold climates. Suggest leaving the gasket cross-over tab intact, blocking the passage, as we live in warm climate and don't need it.
Just make sure you get the 4 intake gaskets with the valley pan for superior sealing.
http://www.1962to1965mopar.ornocar.com/ ... -seal.html
I did not us the extra gaskets, only a thin layer of gasket sealer (Locktite gray RTV) both sides of valley pan.
I have heard guys having endless sh!t with vacuum leaks when using the gaskets?
