351 Cleveland versus 351M identification
Hi could someone possibly help me - I have a bought an80's Bronco and was wanting to know if it was a 351 Cleveland or a 351 M motor - apparently they came spec'd with the 351M but it was sold to me as a 351C and was wanting to know if there was any easy ways to tell the diff visually without having to pull it apart .
Thank you in advance
Re: 351 Cleveland versus 351M identification
"M"??
Clevo has top intake water hose, Windsoer has front intake water hose on top.
Greetings
André
André
351m has a metal rib on the right of the distributor 351c is flat ... I've never used a M but remember being told
If the distributor mounting hole is even with the front mounting surface of the intake manifold, then you have a 351C. If the mounting hole is deeper into the block, then it is a 351M. The front inner corners of the cylinder heads are also raised above the distributor hole on the M vs the C.
If this helps
- image.jpg (49.84 KiB) Viewed 1887 times
Thx a mill for all the help and thx for the pics JL def helps and seriously hope it a Cleveland and not the M series - have boat loads of Cleveland spares and not sure what or if anything will be compatible.
Thx once again
Thx once again
Cleveland spares will sell pretty fast if you can't use them ....
- colin davids
AFAIK the 351M/400M has the bigblock bolt pattern on the bellhousing.
FORD CAPRI PERANA NO. 66
FORD CAPRI V8 DRAG CAR
FORD SIERRA XR8
FORD CORTINA 3.0 S W/CHEVY V8
BMW E30 W/ FORD 347 STROKER
SUZUKI GSXR 1000
FORD SIERRA XR8
SUZUKI GSXR 1000
