Ranger SS
deltaforce
Ranger SS
Post by deltaforce » Mon 02 May 2016, 20:26
Hi guys, does anyone have any details regarding the Ranger SS gearbox. Was it a close ratio, were there any special features, was 4th gear 1:1 etc. I am busy building a 1900 Manta S for historic racing and I know that the original Manta gearbox had pretty wide ratios. The car came with a Ranger SS 'box so I m trying to find out if it is indeed worth using.
Re: Ranger SS
Post by Johann65 » Mon 02 May 2016, 21:49
deltaforce wrote:Hi guys, does anyone have any details regarding the Ranger SS gearbox. Was it a close ratio, were there any special features, was 4th gear 1:1 etc. I am busy building a 1900 Manta S for historic racing and I know that the original Manta gearbox had pretty wide ratios. The car came with a Ranger SS 'box so I m trying to find out if it is indeed worth using.
Owned a 74 Ranger SS, last one sold in Meyerton. Had valve bounce @ 5500 RPM! Rear diff 4.5. Had long range between gears! Tourque curve was flat @ 2250RPM. Have a copy of the owners manual, will look it up!
Re: Ranger SS
Post by ters » Tue 03 May 2016, 05:52
You have a private message DF ;) .
Re: Ranger SS
Post by Johann65 » Tue 03 May 2016, 12:34
Sorry no data on the gearbox in the owners manual
Autobook:
Number of forward speeds - Four
Synchromesh - All forward speeds
Gearbox ratio:
Top = 1:1
Third = 1.37:1
Second = 2.16:1
First = 3.43:1
Reverse = 3.32:1
[/b]
barrydorr
Re: Ranger SS
Post by barrydorr » Tue 03 May 2016, 12:44
Please share some pictures of your Manta and/or you building process.
My Manta has the original Trimatic Getrag box.
I have the two workshop manuals at home which should have all the data on the ratio. only have this data where i am sitting right now
manat transmission.png (37.61 KiB) Viewed 6654 times
My Toys:
1974 Opel Manta 1900 DL
2008 Mitsubishi Outlander
Can-Am ZN
Re: Ranger SS
Post by Can-Am ZN » Tue 03 May 2016, 15:06
Johann65 wrote: Sorry no data on the gearbox in the owners manual
Autobook:
Gearbox ratio:
Top = 1:1
Third = 1.37:1
Second = 2.16:1
First = 3.43:1
Reverse = 3.32:1
I think that's the information that the OP will need to confirm that it is definitely NOT a close ratio box.
Gavin
1974 Chev Can-Am 302
deltaforce
Re: Ranger SS
Post by deltaforce » Tue 03 May 2016, 17:00
Thanks for the info guys, much appreciated. OK so that definitely rules out the SS gearbox, will probably go the BMW route now which will also have the advantage of being 5 speed.
Re: Ranger SS
Post by ters » Tue 03 May 2016, 17:08
I have "created" an Introduction for you Delta ;) viewtopic.php?f=41&t=21664
Re: Ranger SS
Post by IndianaJones » Tue 03 May 2016, 20:33
Are you sticking with the 1.9L CIH engine or going to a XE or Ecotec engine?
Here's a link to a nice tuning guide, might be of interest...
http://www.sbdev.co.uk/Case_Studies/Cas ... eckham.htm
Can-Am ZN
Re: Ranger SS
Post by Can-Am ZN » Tue 03 May 2016, 20:47
deltaforce wrote:Thanks for the info guys, much appreciated. OK so that definitely rules out the SS gearbox, will probably go the BMW route now which will also have the advantage of being 5 speed.
What diff ratio will you be running in the car, if you want to use the BM box?
Gavin
