Calling ford V6 Guru`s
Hi Guys
I have an upgrade essex V6 that has been rebuilt top to bottom. (electronic dizzy and hydraulic lifters)
Now first fire up she runs well and smooth.
next day only the right bank is running, when all 6 leads are connected its a rough idle, remove the left bank and it is smooth.
Heads have been triple checked, valve seats, stems have been triple checked, block has been checked, dizzy was swapped, leads were swapped, firing order has been checked.
No leaks on intake gasket
any advise??
any advise??
Re: Calling ford V6 Guru`s
Hello Marnus!
After swopping dizzys, did you re-install a mechanical one? If so, it might be that the mechanical one is faulty - points, rotor, condenser?
Also, when you checked the leads did they all have spark when you took them off the plugs one by one?
Hope you get it sorted soon
'73 Chevrolet Can-Am
'71 Ford Capri Perana
'84 Ford Sierra XR8
'65 Ford Mustang Convertible
'72 Landy SWB "88 series 3
'78 CJ5 Willys Jeep
'73 Pontiac Grand Prix 400
'84 Ford Sierra XR8
'78 CJ5 Willys Jeep
Hi
I have tested with both elec and mech dizzy same result with both, mech dizzy from running motor.
all plugs leads have spark.
is it mayb a carb issue? 38DGAS Weber
does each bank run on its own barrel?
Are u sure that the valves does'nt stick or that the lifters "pump-up" ??
Hallo Marnus
Now that we've eliminated the dizzy/leads, you can turn your attention to the carbie. If possible, you need to check the vacuum on the intake with a vacuum gauge - you should find an airline at the bottom of the foot piece on the intake manifold. If the vacuum is in-sufficient/low, you will also have the engine running rough.
When you took the leads off the left bank, you increased the vacuum to the right bank as three of the cylinders now have no need for vacuum, thus the engine running more smooth.
Because you've fitted hydraulic lifters and new valve seats, you need to check that the tappets aren't too tight now as the seats are also new and have more beef - even if the book gives you a recommended gap/torque rating, you need to double-check they aren't too tight - this will definitely cause problems with vacuum.....perhaps look at coming down a turn on each tappet lock.
Remember with those Essex engines - rather more rattler tappets than too tight which will also cause possible damaged to the valves/stems.
Hope this helps.
Hope this helps.
'84 Ford Sierra XR8
'78 CJ5 Willys Jeep
'84 Ford Sierra XR8
'78 CJ5 Willys Jeep
Hi V8 Fan
i will have a look at the vacuum in the manifold and revert back.
'84 Ford Sierra XR8
'78 CJ5 Willys Jeep
'84 Ford Sierra XR8
'78 CJ5 Willys Jeep
Hello Marnus - what ever happened with you V6 Essex....were you able to sort out the problem?
'84 Ford Sierra XR8
'78 CJ5 Willys Jeep
'84 Ford Sierra XR8
'78 CJ5 Willys Jeep
i agree with Hano/MarnusV8 fan wrote:Hallo Marnus
Hope this helps.
i just rechecked my 79R setting the cam i run current valves were tight then went to forum and checked settings for cam 35IN 45EX fantastic these essex need precise valve clearance to run smooth also Carb is an issue when they mess around but do the basic check if all is good engine should be running smooth
Hey guys
After being Dr Diagnosis I replaced the hydraulic lifters with solid ones and all issues disappeared.
Strange, motor was always running on the hydraulic ones.
