289 Ford V8 setup
- jacodebeer
Re: 289 Ford V8 setup
Is this T5 gearbox an automatic or manual, you guys are speaking greek here?
- alvin chetty
Jaco,
to fit a 302 or 289 into a courier is a simple process and you dont have to go to any speciality shops to do so. I fitted a 351 into a courier and here are a few ideas
1. the 302 and 289 uses the same oil sump but you will have to get one with the double hump or "camel" sump and matching pick up.
2. the fire wall and tunnel needs very little modification or alteration and that you can do with a 4lb hammer and slight tapping for clearance. I used a C4 automatic and had to cut one ear or square block off the bellhousing for clearance with no tunnel modification at all. cutting off this peice did not compromise the strenght of the bellhousing at all
3. there is a steel crossmember that is bolted to the chassis with 4 bolts. I remove and repositioned it slightly and used 2 of the existing holes but had to drill 2 extra holes.
4. Master parts in Cape town stocks a Block hugger exhaust branches for about R1000 which fits this application perfectly.
5. for engine mountings, I used the original V8 block mounding and made up the lower peice with a 50 X 5mm flat bar and a thich wall tube and high tensile bolt. It did not take more than 30 minutes to make.
6. gearbox crossmember was the original courier re-drilled for the V8 mounting
7. I used a sapphire V6 radiator which mounded directly under the slam panel without much alteration.
you can do this conversion over the weekend except for the propshaft, and exhaust system
Good luck
Good luck
- jacodebeer
this is good stuff Alvin I'll be giving this info to my dad.
We are going to the V8 Shoppe on saterday to go do some shopping...
Is there any good V8 performance part sellers in the JHB area?
V8 shoppe is good also try US connection in Wynberg.
- jacodebeer
hi guys check me and dad went to do some shopping over the weekend
bought some parts here's a few pics
at the V8 Shoppe
the 600 Holley 4 barrel
new and old distributor
this is what the pistons looked like after standing 8years (left) and the clean one
new and old intake manifold
the engine block...
and the rest...
at the V8 Shoppe
the engine block...
and the rest...
Would your dad take me shopping as well!!
Thats quite a large shopping spree, wish I could afford it. Enjoy your new toys.
Greetings
André
André
- jacodebeer
yes it was a little bit to much I also thought, I told him we can get the rest of the stuf later so he gave me this look and tuned me "We are here now, why drive all this way again, when we can make one trip"... I just kept quite the rest of the time eish?
Here's a Courier with V8 for sale if anyone wants one...
http://durban.gumtree.co.za/c-Cars-Vehi ... Z205442288
That's how I roll. Down the hill 'cause the car won't start and the brakes don't work.
- jacodebeer
Hey everyone, flippit but its cold...
I just want to know if anyone knows of someone who has a flywheel for the 289 laying around, I would like to buy it off your hands pleeeaaassseeee!
thankz
thankz
Users browsing this forum: No registered users and 12 guests
