Hi There
I have a 1988 Opel Rekord with a 350 Chevy V8 2 bolt main. There is no Power steering and would like to either convert to power steering or alter the steering box to make it a bit lighter as it's very heavy at the momment.
The Rekord also has stock brakes and doesnt help at all. Which Brake booster would you guys recommend and which Discs & calipers would you recommend.
I was think of using the BMW e46 330i Front Discs & Calipers as they are also 5by120 PCD. And using the Brake MAster Cylinder as well. But not 100% sure if it will work.
Please email all your suggestions and thoughts to jarrodh@stallion.co.za
Cheers Jarrod
WANTED: Brake Upgrade Assistance Required
Re: WANTED: Brake Upgrade Assistance Required
good Choice Jarrod,Jay03 wrote:Hi There
Cheers Jarrod
Johan has a thread for brake conversion you can follow the process and have idea from that thread, the BMW e46 good combination you need a master cylinder to work the caliper power required try chev commodeore 4.1 engine also for the power steering box setup, do you have a power steering pump on the S/B 350 engine
