So what can you do - butcher your car and fit ford/gm bits................NO
The following guide will help you.
US A-Bodies changed suspension design in 73/74 - so their transplant differ a bit - and we never had their disc systems over here
Chrysler over in the Southern Hemisphere has never changed their Basic suspension layout and parts usage - OK the VH Up ward models had a wider track in the rear, and the early cars do not have front anti roll bars. All the models up to 68 and some up to 73 only ever had 4 wheel 9 inch drum brakes on skinny 165 tires..........on 13inch rims with a very odd 5 on 4inch boltpatern. Oh yes the brakes are not power assisted and the earliest cars had a single piston master cylinder...
To put things in to perspective my 160BHP 68 barracuda had this braking system and wheel configuration - my 100BHP JETTA which weighs 10 kg more than the Barracuda has 11 inch discs front 10 inch rear and 205 tires - stock out of the factory scary thought.
Well to upgrade is easy - if you want to stick to the small boltpatern for whatever reason - either buy an hyper expensive R12000 upwards Wildwood kit, or do some scrap yard crawling and try to get hold of a wrecked 69 to 73 American design Val with discs - restore the parts and bolt it in - you will need the Master cylinder and booster, the complete wheel spindle plus caliper and discs - if you want to install an ant roll bar - take the control arms as well as the anti roll bar.
It really is a bolt in operation. In this case replacement discs and drums as well as sealing kits are a bit of a pain bat can be sorted out.
If you want to go for the large boltpatern setup with the larger discs an even larger drums there is one hiccup - the donor cars in this case is the 73 and upwards cars an they have wider rear-end - which you will have to pilfer if you want to fit the same boltpatern front and rear - these rear ends might look the same but are of a much sturdier design- the advantages is - 5 on 4 1/2 inch A.K.A 114.3 PCD rims is not a problem any more, Drums and discs are readily available from brake suppliers, wheel cylinders and seal kits are available, Bigger drums and discs - better stopping power and as a rule dual tandem master cylinder with booster on a bell crank bracket which allows you to free up space next to your engine - no more remote booster.
Please note
Don’t re drill your existing side shafts to the new bolt pattern, do not use adaptor plates - do the right thing - either order special side shafts with the correct pattern or try this recipe
The spring mounting points on the axle need to be moved inboard by about 17 mm each side - take measurement from your original rear-end.
The wider axle moves the wheels more outboard and into the middle of the arch - on the 68 Cuda and the Valiant Charger the gets rid of the Tippytoe stance and allow wider wheels to be fitted without worries about interference - a note here cars with lowered lower wheel arch lip - e.g. 64 - 66 Coda, most sixties to early seventies Valiants PLEASE check your spacing if you go this route!
In my case is detailed the chassis , and refurbished the suspension with new bits, as well as replace all brake and fuel lines with reproduction items - me doing the reproducing
My Donor car was a late model Valiant - Now I have power assisted ventilated discs up front, and big beefy drums in the rear - Oh yes - I am now running 205/70 14 Goodyear GT2's - at 2000 for a full set a good deal , BTW I mentioned HiQ Autowiel in Centurion Before - their new alignment kit has a Data base of alignments specs going to the fifties - apparently the first such system in RSA - Steel rims in 7J compliments of Guestro - they made the originals for the VH upwards series locally, and Imported period correct hubcaps
The whole conversion is to OEM spec so spares are not a problem, and even the garage in Carnavon can repair it.
It handles great, and brakes like crazy
Now to fit the imported rear anti roll bar......
Comparison of original small 9 inch to new 10 inch drums, as well as the wider rear spacing
Front Drum During chassis clean and degrease - I like to clean everything so I can see what I am up against
New discs bolted in and underbody resealed
Rear-end ready to be reinstalled
Shiny is it not?
Shopping list
Big bolt pattern:
Complete brake system plus wheel spindles plus rear-end with drums from 73 upwards Valiant.
Small bolt pattern:
Complete disc system from late 60s to 72 Valiant
Rims from Guestro, brake system rebuild kit from Wingate
Shocks from Koni in centurion
Rear springs reset by Van Zyl spring works
Suspension bushes from Summit racing
Ball joints, etc from Autoparts
Brake lines and fitting from media Hydraulics
Discs and drums skimmed by Centuria Brake and clutch
Elbow Grease ME
