setting hydraulic lifter on 3.4 v6
Hi guys I was hoping maybe someone knows how to det hydraulic valve lifters on a 3.4 v6 I got the intake and exaust gaps from steves after the did a mild profile on the cam 0.35mm inlet and 0.35mm on the exhaust I wana know the process of how do I exactly set them correctly as they are noisy currently any info wud be highly appreciated
- colin davids
Re: setting hydraulic lifter on 3.4 v6
Hi Mohammed
If your v6 does in fact have hydraulic lifters and you used those clearances then it would definitely be noisy.Turn your engine until no. 1 cylinder floats (both valves closed).Tighten your lash adjuster until you feel slight resistance on the pushrod when turning it between your thumb and index finger.Now tighten it another eighth of a turn.Repeat for all cylinders following your engine's firing order.Done.
*N.B. Please make sure that you do have hydraulic lifters before you do this.Some of the later 3.4's came with solid lifters(silver tappet cover) and if you use this method with solids you will definitely have problems.
Hope this helps
Colin
Hope this helps
Colin
FORD CAPRI PERANA NO. 66
FORD CAPRI V8 DRAG CAR
FORD SIERRA XR8
FORD CORTINA 3.0 S W/CHEVY V8
BMW E30 W/ FORD 347 STROKER
1970 MUSTANG MACH 1 MANUAL W/4V CLEVELAND
SUZUKI GSXR 1000
FORD SAPPHIRE 2 LITRE 16 VALVE TURBO
FORD SIERRA XR8
SUZUKI GSXR 1000
