SIERRA XR8 RACER
- colin davids
Re: SIERRA XR8 RACER
Morning.Stripped the xr8 engine and this is the carnage we found.One very broken piston and two more cracked.Bearings look ok though as the crank has been chamfered etc.Rather than take any chances i'm fitting a full set of new pistons and bearings + doing a pressure test + skim on the heads.This circuit racing seems to be a lot harder on engines than drags.The pistons should be here by monday so it will be running sometime next week.Hopefully we'll make it for the next race on 8 june.
- DSC00677.JPG (145.78 KiB) Viewed 6563 times
- DSC00676.JPG (150.26 KiB) Viewed 6563 times
- DSC00675.JPG (140.07 KiB) Viewed 6563 times
FORD CAPRI PERANA NO. 66
FORD CAPRI V8 DRAG CAR
FORD SIERRA XR8
FORD CORTINA 3.0 S W/CHEVY V8
BMW E30 W/ FORD 347 STROKER
SUZUKI GSXR 1000
FORD SIERRA XR8
SUZUKI GSXR 1000
Your efforts are applauded, but really.....when has FORD ever produced an efficient,powerful and relaible block of cast iron??????
stick a BB Chevy in that thing....tell him Mr Chetty
2003 GTI 4
2014 Jetta 6 TSI
1981 Chevair V8 350 ...in CPT with Jack
Rover hopefully twin turbo 305 soon
68 Valiant 200 - awaiting 318 V8 transplant
75 HQ Kommando - 350 V8
2014 Jetta 6 TSI
- alvin chetty
I've been running the same motor in my car for the past 4 years MrRay and all I did was replace head gaskets twice.mantaray wrote:Your efforts are applauded, but really.....when has FORD ever produced an efficient,powerful and relaible block of cast iron??????
I don't want to talk about the reliability or (un)reliability of the chevy but when a chevy blows, it really destroy itself. Collins engine is the original motor that came with that car in 1984 and it still went around the track without ending up on a tow truck. a new set of pistons and he's ready to run.
BTW a ford does not need nitrous to make it go
- colin davids
Hey Ray,remember this car?12.3 sec quarter mile n/a on a 302 with stock cast iron heads, stock pistons and pump fuel.What was your best time without the blue bottle?How about an all-motor challenge.I was going to leave my capri on the back burner for now but i think i'll put it together if you accept ,although i'm pretty sure you won't.mantaray wrote:Your efforts are applauded, but really.....when has FORD ever produced an efficient,powerful and relaible block of cast iron??????
btw, my new motor will definitely go a few tenths quicker so don't bring a knife to a gunfight.
- DSC00672.JPG (148.34 KiB) Viewed 6549 times
FORD SIERRA XR8
SUZUKI GSXR 1000
FORD SIERRA XR8
SUZUKI GSXR 1000
- alvin chetty
btw, my new motor will definitely go a few tenths quicker so don't bring a knife to a gunfight. [/quote]
12.3?????? when???/ the only time i saw this tin can was once at drags, if you had said, 12.3 , driven to and back from the track, then hell i would be impressed. know one i know trailers a 12sec car unless it has liscence issues of which i am sure your Glenryck Pilchards stripped out wheelbarrow Capri has.
2003 GTI 4
2014 Jetta 6 TSI
2014 Jetta 6 TSI
- colin davids
mantaray wrote:Hey Ray,remember this car?12.3 sec quarter mile n/a on a 302 with stock cast iron heads, stock pistons and pump fuel.What was your best time without the blue bottle?How about an all-motor challenge.I was going to leave my capri on the back burner for now but i think i'll put it together if you accept ,although i'm pretty sure you won't.
12.3?????? when???/ the only time i saw this tin can was once at drags, if you had said, 12.3 , driven to and back from the track, then hell i would be impressed. know one i know trailers a 12sec car unless it has liscence issues of which i am sure your Glenryck Pilchards stripped out wheelbarrow Capri has. [/quote]
So i take it all that ranting and raving means you decline.Ray,you shouldn't take it so personally boet.I have nothing against chevies.Both brands have their good points.Fords just have more.
FORD SIERRA XR8
SUZUKI GSXR 1000
FORD SIERRA XR8
SUZUKI GSXR 1000
- colin davids
Morning
Fine car racing at killarney was really good yesterday.My rebuilt engine gave no problems whatsoever and the cooling is fully sorted.The problem now is that after two laps just when the tyres start to get sticky the brake pedal goes almost all the way to the floor.I reckon 5.1 racing brake fluid and braided hoses should help in the next race.The car ran 1 min.36 seconds but i feel low thirties are quite possible when the brakes are sorted and i learn to drive a bit better.Thanks Tony (killarney racer) for a good run in the second heat. I definitely have the legs on the straight but you totally destroy me in the bends. Maybe next time.
Colin
Colin
FORD SIERRA XR8
SUZUKI GSXR 1000
FORD SIERRA XR8
SUZUKI GSXR 1000
Colin, get your hands on AP 600 brake fluid. Expensive, but worth it. Dave Sinclair in Strand (021) 854 6331) is the local agent as you cannot fly it from JHB and it has to come down road freight Alternative would be fluid from Performance Friction. Are you running any cooling ducting to your discs? Also a big help.
1967 MGB GT V8
1973 Chev Firenza Can Am
1978 Ferrari 308 GTB
2010 Mini Cooper JCW
- colin davids
Thanks CanAm.I will definitely get it from them.Did not think i would need brake ducting in fine cars but i was clearly wrong because speeds on the straights are pretty high.We do have some aluminium flexible ducting that i could use.This is the kind of advice that can only come from race experience.Thanks.CanAm17 wrote:Colin, get your hands on AP 600 brake fluid. Expensive, but worth it. Dave Sinclair in Strand (021) 854 6331) is the local agent as you cannot fly it from JHB and it has to come down road freight Alternative would be fluid from Performance Friction. Are you running any cooling ducting to your discs? Also a big help.
Pity they dont have a race fluid for the driver to improve my cornering ability.
Colin
FORD SIERRA XR8
SUZUKI GSXR 1000
FORD SIERRA XR8
SUZUKI GSXR 1000
