Hi all,
I'm looking for below parts:
- diff for my Ford Capri to handle the 302w, would be nice to get one I can just install and don't have to modify or build. I have the current diff which I thing is original one from the 2L capri. I also have what I think is a Ranchero diff. Willing to trade both.
- 4 barrel Holley 600cfm + inlet manifold
- exhaust headers
- engine mountings to fit the 302w into my Capri
- shifter for C4 auto box
various parts needed for Ford 302W
Re: various parts needed for Ford 302W
Just check the 2L diff, if it has a M75 plate you should be good, I have seen fair amount of gents using the M75 with the 2JZ Turbo engine pushing 800Hp.
Cortina, Capri and some bakkies had the M75
Would probably be cheaper to have the diff checked and mayb ratio change at Gearmax
Thanks for the advise Marnus,I'll have a look at the diff this weekend.marnus wrote: ↑Thu 04 Oct 2018, 13:55Just check the 2L diff, if it has a M75 plate you should be good, I have seen fair amount of gents using the M75 with the 2JZ Turbo engine pushing 800Hp.
Just an update on the above. I did manage to find a Holley + manifold. Decided to use my stock cast iron exhaust manifolds.
Users browsing this forum: No registered users and 20 guests
