Ford 260 Timing Cover
Looking for the early timing cover for a small block from 1963/1964 that takes the "short " aluminum water pump. Cover part number C4AE6059B. Cheers
- zahistorics
- zahistorics
Re: Ford 260 Timing Cover
Google tells me a D3OZ-6019-A should fit.
My reading suggests these covers are not engine capacity specific, but rather year specific.
I think an early 289W or 302W (or even 351W?) cover will fit. Main difference is the number you quote has a cast timing pointer. Later covers have a bolt on pointer.
hi Guys i have one. i would like to swap for normal 302 cover off my 289. i have a brand new 302 water pump but does not fit on the 260 289 cover
Hi John. Covers not the same as the 289 ones. The water pump area is deeper at the impeller . Cheers Nick
- zahistorics
