U-Joint GMB-210-1200
If you are not a regular forum member, please introduce yourself in the Indroduce yourself/Welcome to new members section. Tell who you are, where you are from and some background details. Your advertisements will be deleted if you don't.
Driveshaft decided to fall out today, the U-Joint is pretty worn. looked up and found the part im looking for is GMB-210-1200 and it doesn't seem to be available here. my guess is its imperial sizing?, so my dumb question is; is there some universal universal joint sizing whatnot that im not aware of, or is there supplier that will have this.
Re: U-Joint GMB-210-1200
There is a supplier that will have this.
GMB is only one manufacturer of universal joints, other manufacturers might use a different part number.
For what vehicle is it, and does it have it's standard driveline?
Ok thanks, didnt know gmb was manufacturer, i thought it was part of the part no. Its for a d100 dodge 1959 and it is the srandard driveline.
Have you joined the Mopar owners group yet? On Facebook: https://www.facebook.com/groups/moparownerssa/
Have you found GMB part nr 2101200?
If Autozone/Midas, etc doesn't have stock, even BMG/Bearing Man should be able to supply.
haven't found one yet but i haven't been looking been rather busy and it doesn't look like it will be a quick swap, it will have to be welded in somehow. Bakkie did however get a new carb and master cylinders
[quote=it doesn't look like it will be a quick swap, it will have to be welded in somehow. [/quote]
Better post some pics - sounds like you are barking up a very wrong tree.
Front segment is pressed fit. Probably internal clip.
Pardon my ignorance!! Is that not a prop shaft!
Used to be known as Johann65.
1966 Opel Rekord Current running project
1972 Chev Kommando (V8 Conversion) Sold to Mantaray
1965 Chev Malibu Sold
1966 Volkswagen Sold
1953 Renault Break (Sold as scrap!)
1954 Hillman Californian Sold
1954 Triumph TR2 Sold
Users browsing this forum: No registered users and 9 guests
