1969 FORD CAPRI - UNFINISHED DRAG RACE PROJECT FOR SALE.
* Body only
* No Papers
* Previously had 302/347ci V8 SBF.
* Professionally built exhaust headers & 76mm exhaust system with X-Pipe (Value 11.5K).
* Ideal drag/circuit racing or spin project.
* Windscreen **NOT** included in the sale.
* Full roll cage tied into chassis rails (10 point - Value R8.5K).
* Sub frame connectors welded in (Value R2.5K).
* 2 Bucket seats (Driver's side Harness).
* Battery box behind Driver's seat.
* MSD digital 6al (PN 6425) Value - R3.5K.
* NOS Cheater plate kit with purge + 2 X 10lbs bottles (Value - 9K).
* Holley time based nitrous controller & safety solenoid plumbed & wired in (system works) Value - R3.5K.
* HKS voltage stabiliser (value - R1.5k).
* Fibreglass Bonnet with vents.
* Removable Steering Wheel.
* Remote fitted Alpha Brake Booster (under passenger fender).
* Manual Line Lock.
* Professionally rewired with switch panel & external kill switch (Value - R7.5K).
* Hurst ratchet shifter (Value R4.5K).
* Fitted Ford 9 inch Diff (4.11 Limited Slip centre) Value - R8K.
* Old school EVO R Aluminium mags 15 inch-Value 5K)
All the above in good condition & open to viewing.
A little TLC will make for an awesome project.
**Option 1** - All the above for R25500.00
**Option 2** - Minus MSD Ignition, NOS kit, NOS Controller & HKS Unit - R15500.00
**Option 3 - **Minus LS diff centre, MSD Ignition,
NOS kit, NOS controller & HKS Unit - R12500.00
***GEARBOX ***-
* Built C4 Auto Gearbox (Big C4) with 500hp rebuild kit (broaderperformance.com) (kit Value 5K).
* Redneck Performance reverse manual valve body, HiPerf Billet Servo + Pro-tree trans-brake. (Value 15K including Torq Conv & Billet Servo)
* Redneck Performance 9.5 inch 5200rpm stall torque converter.
* Works flawlessly.
All the above is in good, 2nd hand condition & open to viewing
**R16800.00**
***ENGINE SPARES***
Scat 302/347 SBF stroker rotating assembly.....
* Scat Series 9000 cast crank (20/10)
* Scat **H-Beam** Con-Rods - ARP Series 2000 bolts
* Keith Black Forged dome pistons.
* Stroker Kit Value with H Beams - R25K+
* Total Seal ring kit fitted.
* No bearings
* No engine block
* ARP Main stud kit
* Probe Main stud girdle
* TCI (SFI Approved) 164 tooth Flexplate
* Summit Racing SFI Approved Crank Damper
* SA Gear double roller timing chain kit
* Water Pump
* ARP Hardware
* Hi torque starter
All the above is in very good, 2nd hand condition & open to viewing
R38750.00
* Canfield 195cc Aluminium Cylinder Heads with Ferrea 6000 series valves (int 2.02/exh 1.60).
* Heads have a triple valve spring setup for .630 lifter camshaft (SFT)
* Thick wall, heavy duty pushrods
* Scorpion 1.73 ratio roller rockers
* Probe roller rocker stud girdle with poly locks
* Victor Jnr intake manifold (port-matched to the Canfield heads)
* Wilson Manifold 1 inch Tapered Carb Spacer (4150)
* Ford Racing Valve covers (Tall)
* MSD Pro Billet race distributor
* MSD HVC Coil
* MSD 8.5mm Super Conductor plug leads
R43500.000
Feel welcome to reference Summitracing.com for current costing.
Contact Robbie on
062 959 0426 (Call or Whatsapp)
1969 FORD CAPRI - *SOLD*DRAG RACE PROJECT FOR SALE
- ● All adverts must include pictures and a price. This is not a bidding site.
- ● Please respond to enquiries, if you don't respond your add will be removed.
- ● Please change an item heading to SOLD when it is sold.
- ● Members are allowed 12 adverts per year to make sure the forum stays an enthusiast platform.
- ROBBINATOR
- CAPRI 1.jpg (273.98 KiB) Viewed 7973 times
- CAPRI 3.jpg (326.62 KiB) Viewed 7973 times
- TOP END HEADS 2.jpg (149.6 KiB) Viewed 7973 times
- SCAT KIT.jpg (451.3 KiB) Viewed 7973 times
- SCAT CRANK.jpg (449.4 KiB) Viewed 7973 times
- CARB-INTAKE.jpg (152.99 KiB) Viewed 7973 times
- C4 GEARBOX 2.jpg (58.32 KiB) Viewed 7973 times
EXPERIENCE.....tells you that a Tomato is a fruit.
WISDOM....tells you that it does not go in a fruit salad.
GOOGLE....can help avoid your customer's car from burning out and then been summonsed to court.
Re: 1969 FORD CAPRI - UNFINISHED DRAG RACE PROJECT FOR SALE
Long time Robbie, welcome back!
- ROBBINATOR
Hey Ters.......Howzitt??
BODY SOLD!!!
BODY SOLD!!!
- ROBBINATOR
SOLD!!
Ad Closed.......Thanks guys.
