1958 Chevy Apache unfinished project
Sell your muscle car
If you are not a regular forum member, please introduce yourself in the Indroduce yourself/Welcome to new members section. Tell who you are, where you are from and some background details. Your advertisements will be deleted if you don't.
  • ● All adverts must include pictures and a price. This is not a bidding site.
  • ● Please respond to enquiries, if you don't respond your add will be removed.
  • ● Please change an item heading to SOLD when it is sold.
  • ● Members are allowed 12 adverts per year to make sure the forum stays an enthusiast platform.
Turbine
Post by Turbine » Thu 16 Jul 2020, 12:58
1958 Chevy Apache unfinished Project
- Chassis has been sandblasted, primed and painted
- Cab, body panels & parts - sandblasted
- rust repaired
- primed
- steel rear steps & fenders
- need new load bin
- windscreen not cracked
JAG Suspension
- Front suspension fitted
- Rear suspension assembled
- sandblasted
- primed and painted
- overhauled with brand new Jag parts,
- ball joints
- Tire rod ends
- bushes, upper & lower
- wheel bearings front & rear
- shocks
- 2x coil rear springs
- 4 x brake discs
- all brake pads
- all rear U joints
- bearings front and rear
- Callipers need to be recon
TYRES & Rims all New x4
- 265/65/R20
- Torque thrust rims
- billet steel 20mm spacers
- M14 studs
- chrome wheel nuts
ENGINE
- Chev 454 Gen5
- TH700R4 box
- GM forged pistons
- STD hastings chromoly rings
- ACL Big ends and mains
- Comp 268H cam and lifters
- S.A gear double row timing chain
- Melling M55hv oil pump
- Fel Pro gaskets
- Pro Comp intake manifold
- Holly 770 street avenger carb
- Pro form HEI 10.5mm plugs wires
- Stainless steel mid length headers
- airtex water pump
- chrome alternator with pulleys and brackets
- 14" chrome air cleaner
- accelerator bracket
- TV cable linkage
- block was honed and measured
- crank micro polish
- heads recon and pressure tested
- block cleaned and painted
PARTS
Most still in boxes sealed
- 6 gauge set GPS speedo
- electric window kit
- Chrome tilt column shift steering
- aluminium radiator
- 2x oil coolers
- 16" S curve 3000cfm electric fan
- 15 circuit wiring kit
- stainless steel fuel tank 100LL fits in chassis
- stainless radiator hoses
No papers
Chassis, Cab, body panels with jag suspension,
rims and tyres & windscreen R110k
Or everything for R220k
Contact 072 303 0774 for viewing & more info
Situated in Klerksdorp area, North West Province
Can send more pictures upon request
